Home Forums Products Stompboxes play mode changing my preset values Reply To: play mode changing my preset values
#122048
wedelich
    Hi anth,
    From what I'm reading, that seems normal.  The bank/play mode divide is mostly for footswitch operation.  You only call up a saved preset explicitly in bank mode.  If you put it in play mode, it still operates on whichever effect/preset was loaded.  As long as you don't save with the new settings, you should be able to navigate to a different preset and then back to the orginal, retaining the original values.
    -Russ
