Home › Forums › Products › Stompboxes › Multi-Pedal Sync through Aux/Switch › Reply To: Multi-Pedal Sync through Aux/Switch
May 3, 2011 at 9:43 pm
#122053
Sounds reasonable. You may need a little care to avoid ground loops, but this is not normally an issue if they are mounted on a pedalboard.
