Home › Forums › Products › Stompboxes › Expression pedal will not work with Pitchfactor via MIDI… › Reply To: Expression pedal will not work with Pitchfactor via MIDI…
#122101
wedelich
    Hi fredp322,
    As a temporary workaround for any immediate gigs, just simply plug any cable into the exp. pedal jack on the back of the PF.  It doesn't have to be plugged into anything else on the other end.  You should be able to use Exp. Pedal over MIDI with this configuration.   Can you confirm this works?
    -Russ
