Home Forums Products Stompboxes Expression pedal will not work with Pitchfactor via MIDI… Reply To: Expression pedal will not work with Pitchfactor via MIDI…
#122109
    FCB1010 -> PitchFactor 3.0.0beta[16]
    RCV CTL = CC xxx -> PDL (only)
    MIDI Channel 2 transmit (FCB) & receive (PF)
    Output = THRU
    CLK IN = ON
    I can confirm the same over-MIDI results as the OP in the 21:2 preset without an expression pedal plugged in.  And I can report the "plug" workaround does correct the behavior for that preset.  What I find puzzling is that that the same MIDI input works as expected on many other presets – with or without a plug inserted in the EXP PED jack.
    These odd results seem to be isolated to presets based on the PitchFlex algorithm.  I never noticed this before; probably because I always have an expression pedal AND MIDI input connected to the PitchFactor.
