Home Forums Products Stompboxes TimeFactor question: why the volume bump when the effect is engaged in mono? Reply To: TimeFactor question: why the volume bump when the effect is engaged in mono?
#122127
I'm running the following gear (summarised), set-up in stereo, but my issue is only for the case I'm running in mono (Output 1 only):
– Guitar -> comp- > clean boost/OD -> BadCat 2-Tone tube preamp ->  Boss DD-7 always on (here the signal gets split): -A -> dry out from the DD-7 -> Timefactor input 1 -> Output 1 -> amp A
                                       -B -> wet side of the DD-7(which is the same as dry, just a couple of milliseconds delayed, for a thickening effect) -> Timefactor input 2 -> Output 2 -> amp B
When using the above set-up in stereo everything is just fine, but as soon as I'm going mono (Output 1 only and with the DD-7 in bypass) I have this issue. The same TF settings that work just fine in stereo give me now volume bumps in mono.
