Home › Forums › Products › Stompboxes › timefactor settings for modulation sounds › Reply To: timefactor settings for modulation sounds
Let me preface this by saying I've got all 4 Factors, and the ModFactor covers a lot of the ground you're looking for. Space is by far the best sounding and most flexible stompbox reverb I've ever heard. However, your question concerns the TimeFactor. While I usually get these effects from other Factors, I'll try to point you in the direction of a few TF factor presets that hopefully you can use as a starting point.
(to do flange with a chorus, turn delay dowb below 12ms or so and turn feedback up)
Chorus: 5:5 Classic Chorus
35:1 ChorusyTrem
45:2 Chorusphase No Delay
Phaser: 21:1 Lazyphasy
35:2 Flaser
38:1 Phasery Band
38:2 Phasery Band 2
43:2 Phasery Banddelay
Flanger: 49:1 Trashcan Flange
Leslie: 2:2 Bridge of Sighs
Reverb: 1:2 Airplane Hanger
13:1 Multitap Hall
13:2 Ambient Multitap (turn slur up if necessary)
16.1 Springy Verb
I'm sure there are more… This is just what I pulled out of the TF preset list that I thought might get you in the ballpark. At least, I hope they'll be good starting points and with a little tweaking, you should be able to find what you're looking for or come very close.
