Home Forums Products Stompboxes How can I bypas presets on TIME/MOD/PTICH FACTORS at same time? Reply To: How can I bypas presets on TIME/MOD/PTICH FACTORS at same time?
#122192
fkalich
    I don't think it is crazy, there are just some compromises one has to make.  It is pretty hard to design a product that does everything, that is not cumbersome to work with.    I might suggest a true bypass footswitch to take them all out of the loop.
    For one thing, unless I am missing something, the bypass  toggle using midi  is a switch,  once your pedals are out of synch (some on, some off), you will be turning some on and some off when you switch them all with the midi solution.
