Home Forums Products Stompboxes Space – increase the Decays in DualVerb to infinate? Reply To: Space – increase the Decays in DualVerb to infinate?
#122219
I'm using SPACE in such a way that I have the mix knob assigned to an expression pedal so I can fade the effect in and out as I play. One downside to this is that going ccw on the knob cuts both the wet signal and the trails, so as I move the pedal back to toe-up, the reverb unnaturally decays down similar to something like a post effect, master level control.
Would it be possible to have an option where the reverb trails as the mix knob is adjusted, so that the mix knob is effectively adjusting only the input signal level into the reverb engine? I imagine the wet (and possibly dry) level would still have to be configurable as well…somewhere.
Thanks for listening.
