Home › Forums › Products › Stompboxes › Musicom Lab EFX 3- Help…. › Reply To: Musicom Lab EFX 3- Help….
June 6, 2011 at 3:48 pm
#122233
leifer:
Also, is there a way to control all the pedals with one expression pedal? I've seen a lot of talk on that- But, no real answer.
If you, or someone you know, can make cables, you can use a 3-way Y lead to connect one pedal to all the pedal inputs (only tip and sleeve needed).
Make sure it is an expression pedal (low impedance) rather than a volume pedal (high impedance).
