Home Forums Products Rackmount H8000FW Midi CC values Reply To: H8000FW Midi CC values
#122287
sean.e
    I don't use the same controllers as you, but I do experience similar sluggishness in my algorithms when sending continuous streams.  I don't know if the problem is algorithm construction or inherit to the box though.  Lag isn't an issue when I use single messages for example to select an input on an iswitch.
