Home Forums Products Stompboxes Timefactor says “Test1.2” on powerup and no switches or buttons work… Reply To: Timefactor says “Test1.2” on powerup and no switches or buttons work…
#122292
    The messages tell us that the left hand switch (K_SW1) is stuck in the on position. It may just be stuck mechanically (wiggle it a bit to see if you can free it), or the switch itself may be damaged or fault and need replacing..
    If you can't free it you will have to contact support@eventide.com
