Home Forums Products Rackmount H8000FW lost presets Reply To: H8000FW lost presets
#122334
    It may well be your criteria settings. You could try a "clear setup" to be sure that everything is visible.
    Also, look to see if there are any ranges of numbers missing, not just individual presets. This is unlikely, but could indicate a memory problem. Check also for errors at startup.
