Home › Forums › Products › Stompboxes › Midi Bypass Command = True Bypass? › Reply To: Midi Bypass Command = True Bypass?
#122369
    The bypass mode is configurable, to either relay (TRUE) bypass or dsp (wet/dry) bypass.
    This setting will apply to either MIDI bypass or footswitch controlled bypass.
    So, it should do what you want.
