Home Forums Products Stompboxes MIDI Control unit placement for Eventide Space & Line 6 Pod 2.0 Reply To: MIDI Control unit placement for Eventide Space & Line 6 Pod 2.0
#122389
badmelonfarmer
    Hi there,
    this is due to the way the POD is handeling the MIDI in OUT or THROUGH when it goes out of the POD and into SPACE.
    Do you have Space and the POD on different MIDI Channels?
    Can you set the POD's MIDI output to THRU rather than OUT? Because if you have it set to OUT it usually means that the MIDI commands that are incoming from the previous device are not sent out, unless it is set to THRU.
    If you don't want to change the MIDI routing and assuming the POD does not send any commands to the space (eg timesync), you could look at getting some sort of MIDI splitter that takes a single feed from the PEAK controller and splits the connections into two …one cable goes into the POD and the other cable goes into the Space.
    This would be fine, unless there is some interaction between the two, eg timesync… then you get into MIDI merge boxes.
