Home Forums Products Stompboxes Tap Tempo Dilemma – Ground Control with Pitch/Mod/Time Factor Combo Reply To: Tap Tempo Dilemma – Ground Control with Pitch/Mod/Time Factor Combo
#122488
bryguy
Thanks folks for the replies, it definitely gives me some ideas.
I'm leaning towards using a MIDI THRU 1 to 2 splitter on the output of the GCX, so one output goes to the Pitchfactor.   I'll take the 2nd output of the MIDI THRU, merge it with the output of the Pitchfactor via a MIDI merge box and the combine them on the input of the Modfactor and let everything go downstream from there.  Not sure if that will work, but it will be worth a shot.  Looks like it will be a couple of weeks at least before I can get the boxes as they are on backorder, but I will let people know if it works.
Worst case scenario, I'll make an external momentary switch to go into the AUX inputs of all 3 boxes, but hoping to avoid that path, but at least know that it is an option.
Thanks again.
