Home Forums Products Rackmount Building a remote with MIDI Touch for iPad (or TouchOSC and MAX) Reply To: Building a remote with MIDI Touch for iPad (or TouchOSC and MAX)
#122583
Doug Wellington
    I don't use an iPad, but I have built a remote controller for the Harmonizers.  I can't help you with your second question, but in answer to your first question, check out Eventide's Technical Note 98.  It has the codes for the buttons…
    Technical Note #98
    As for MAX, do you know if it can talk to a serial port, or is it only MIDI-based?  If it only communicates via MIDI, I think you'll be frustrated with the slow performance…
