Home Forums Products Rackmount H8000FW routing limitations Reply To: H8000FW routing limitations
#122598
nickrose:
Orville, the H8000's more limited predecessor, was pretty much anything to anything. The H8000 has a few restrictions, mainly associated, as you observe, with the Main-in and Main out blocks.
But, it's not as bad as you think. There's no reason why in the above example you cannot connect all the dsp inputs, rather than just two. Equally, the Main-out block allows two inputs to eah channel, allowing the dsps to be run in parallel.
Similarly the FW,  AES8 and ADAT in can be connected directly to FW, AES and ADAT out, without going through the dsps. The main restriction is that the Analog in and AES4 inputs can only connect to Main-in, while Main-out is hardwired to Analog and AES4 out.
Can you explain the bolded part? I still don't see how to connect more DSP inputs in my first example if I need all analog ins and one clean pair of firewire.
Also you wrote that FW in can be connected directly fo FW out, which would really help, but the routing utility doesn't allow that. Once again I need to take the detour through the Main in and Main out funnel.
