Home › Forums › Products › Stompboxes › Eventide: MIDI Sync on Space does not work. Please fix it. › Reply To: Eventide: MIDI Sync on Space does not work. Please fix it.
September 8, 2011 at 4:02 pm
#122632
I definitely understand what you're saying about the rounding of the sync, and I figured there was something going on like that.
The issue is that patches using the echo are not in sync with the drum machine. They are slightly off, and when I do cascading delays with the timeline, the space is definitely out of sync. Additionally, I can't use the sync thru because the midi clock isn't precise.
This is only an issue because I bought the space to have tempo synced reverse reverbs.
