Home Forums Products Stompboxes Master Volume Reply To: Master Volume
#122646
achaput
    New in Version 3 Software is
    Output Level Control
    TimeFactor now gives you the ability to individually adjust each Preset’s Output Level.
    In PLAY Mode, holding down the Left Footswitch for 2 seconds from
    Bypass state puts the unit into Active and also puts the unit into
    Preset O/P Level Adjust Mode. While the
    footswitch is pressed and
    held the display will show “OP 0dB” (default). While continuing to hold
    the footswitch down you can optionally turn the Encoder Knob to adjust
    Preset Output Level from –20dB to +6dB in 1dB increments. Preset must be
    saved to store this setting.e
    To adjust the Output Level in BANK Mode, press and hold the Left or Middle Footswitch while in Bypass.
    For info on updating software, visit this link.
