Home › Forums › Products › Stompboxes › ModFactor Phaser types, shapes and types › Reply To: ModFactor Phaser types, shapes and types
September 14, 2011 at 3:00 pm
#122656
Thanks a lot man!
I've been doing some experiments… I see that bottom row "wiggles" the parameters on the top? ..does this mean, they make the parameters dynamic like moving them up and down?
Also and I may be incorrect about this but other flangers and phasers I tried they used to be active and continuos, instead of using a "sensitivity parameter" which triggers the phase.. Do you know if there is a way no to use sensitivity to trigger the phaser and just be active all the time?
Thanks again!
