Reply To: Help with POWERFACTOR.
Home Forums Products Stompboxes Help with POWERFACTOR. Reply To: Help with POWERFACTOR.
#122658
CIOKS power support
For the Whammy you'll need 9V AC and the EHX English Muffn' needs 12V AC. Since the PowerFactor only provides DC voltages these two pedals can't be powered with PowerFactor. Deluxe Memory Man and Deluxe Electric Mistress (if your Mistres is Deluxe) both need 24V DC, which is also a bit of a problem with the PowerFactor. In fact your mix of pedals needing two isolated AC voltages, 24V for two of the pedals and several other 9V ones is not an easy task. I'd have a look at CIOKS AC10 and CIOKS DC10. These two in combination or the PowerFactor plus the AC10 would power them all.
Best,
Poul Ciok
