Home › Forums › Products › Stompboxes › SKB Stage 5 › Reply To: SKB Stage 5
#122702
achaput
    It sounds like there is enough current on the SKB. However please make sure the polarity of the power connector is tip positive. Remember, we recommend the PowerFactor,
    which can run up to three Eventide Stompboxes plus up to 4 9VDC/100mA
    pedals. The PowerFactor carries a 5 year warranty and includes
    the cables required to power 3 Eventide stompboxes and the special
    mounting plate for PedalTrain pedalboards.
    **Users may try non-recommended third party power supplies at their own risk. Resultant damage is not covered under warranty.**
    See the full power specs below-
    Power Supply
    What are its specs?
    5.5 x 2.5mm barrel, tip positive.TimeFactor can operate from a 5W power source that supplies regulated 9 to 12VDC max.
    The
    minimum required power ranges from a maximum of 4.5W at power up (all
    LEDs lit) to about 3.6W in normal operation depending on how many LEDs
    are lit.
    For a regulated 12VDC, the current requirement is 380mA at power up and 300mA in normal operation. Do not use unregulated 12V.
    For a regulated 9VDC, the current requirement is 500 mA at power up and 400mA in normal operation.
