Home Forums Products Stompboxes audible reverb adjust when switching presets Reply To: audible reverb adjust when switching presets
#122745
badmelonfarmer
    Guess you might have spillover enabled and different tempo between the two settings, as the tempo is faster in the second preset the pitch rises, same as when you change tempo on a delay.
    You could set global tempo or disable spillover to se if it goes away
