Home Forums Products Stompboxes audible reverb adjust when switching presets Reply To: audible reverb adjust when switching presets
#122747
badmelonfarmer
    Ahhh, as you said reverb … I assumed you meant Space.
    But the same is probably true to anything where the repeat changes tempo, even within the same algorithm.
    I would still try either, having global tempo, presets with the same tempo or disable spill over.
    My guess one of those should give you the answer
    Cheers
    Martin
