Home Forums Products Stompboxes Pitchfactor: Allow other parameters to be controlled via expression in Pitchflex mode!!? Reply To: Pitchfactor: Allow other parameters to be controlled via expression in Pitchflex mode!!?
#122802
achaput
    Yes, this makes sense. We decided to "hardwire" the expression pedal to "flex" in the PitchFlex algorithm to make it plug and play with no fuss. There are no current plans to change this.
    In the meantime, there is a way to do what you want if you use MIDI to control the other parameters. You would just need a MIDI controller with expression pedal capabilities.
    Alan
