Home Forums Products Rackmount 5.61B Test is a disaster on H8000FW Reply To: 5.61B Test is a disaster on H8000FW
#122826
    Glad you like it – but, you should probably stick with the released version.
    If you still have your wordclock problem on going back to V5.5, it is probably a hardware or connection issue at your end – I can not see a problem on my V5.6 unit, so don't think it is software.
    It sounds like your wordclock signal is marginal – make sure that it is properly terminated as described in the UM and that the source, cable and terminator are all the same impedance. Try a different and shorter cable to see if it makes a difference.
