Home Forums Products Rackmount 5.61B Test is a disaster on H8000FW Reply To: 5.61B Test is a disaster on H8000FW
#122830
violetpow
    Hi Nick,
    1.) The H8000Fw is direct connected with a RME Fireface via wordclock. Terminator is on the H8000 WC out. The Fireface is running and I switch the H8000 on.
    2.) The H8000 booted up on 5.6.b1. After booting up i see the preset in the display and the 44.1 kHz light is on, the "ext" light is flashing. I press the "setup" button and see the clock menu screen. In the clock menu is the "source" set to wordclock, the samplerate is 44102 , ADAT status is "slipping" and Firewire1 is unlocked.
    3.) I expect that the wordclock is synced (no flashing "Ext" light) after booting up, like before. As i wrote before, if i pull now the WC cable out and back in, the ADAT is not slipping and the "Ext" light is on (not flashing)
    I tried to boot without ADAT I/O connection but is the same.
    So, waht can i do?
