Home Forums Products Stompboxes TF & Aux Switch: work differently between bank and play modes? Reply To: TF & Aux Switch: work differently between bank and play modes?
#122848
greiswig
    I'm not following this.  What I'd like to be able to do is switch up and down between presets (stored combinations of FX, parameter settings, and a name) using the footswitches.  I can currently only do this easily between two presets in bank mode.  I was hoping to do more than that using the aux footswitch.  I'm not seeing a ready explanation of how to do this on p. 32-34 in the manual.
    Another thing that isn't clear is whether the settings that you're recording (e.g. TIP > TAP TEMPO) apply globally (to all presets) or only to the preset you're in when you enter the system mode.
    Thanks much for any help!
