Home › Forums › Products › Stompboxes › Factor Stompboxes MIDI clock Question › Reply To: Factor Stompboxes MIDI clock Question
December 5, 2011 at 3:57 pm
#122899
Midi clock sync will work if you tap on an aux switch. You just have to enable MIDICLK out on the pedal you want to be the clock master, and enable MIDICLK in on the pedal you want to be the clock slave.
-Russ
