Home Forums Products Plug-Ins Eventide TDM Reverb IN PTHD10 Win7 x64 Reply To: Eventide TDM Reverb IN PTHD10 Win7 x64
#122935
neilhester
    Ok so ive worked out what the problem is,
    Its happens to me when i create a new Aux Input track and insert the Eventide Reverb, Bang!!
    -theres the screaming feedback
    If i look at the meters on the Eventide Reverb plugin both are full whack, if i pull the input fader down the feedback goes away.
    Its because there is no input chosen for that Aux yet, if i select an input bus for the Aux, the noise goes away and i can use the reverb as normal.
    So i guess its a bug with the plugin not having an input selected yet feeding back on itself.
     Something you Eventide guys might want to fix in an update :0)
    incidentally Eventide if you are reading this and need some beta test help with new versions please get in touch , i already have lots of beta test experience with several of the most well known pro audio manufacturers 😉
