Home › Forums › Products › Rackmount › H8000FW with DP › Reply To: H8000FW with DP
December 28, 2011 at 10:39 pm
#122965
You are right. I had actually done everything you mentioned, except I used a different preset. In any event, I got it working. Since I couldn't find the H8000 on the insert pull down, I sent audio out to the H8000 via an aux send and back in through an aux channel. It worked! Thanks for your input.
Rich
