Home Forums Products Stompboxes to send a MIDI start signal from SPACE to Moog MuRF. Reply To: to send a MIDI start signal from SPACE to Moog MuRF.
#123019
    Quote:
    a "Midi Start Signal" will do this perfectly, the pattern would reset to the beginning as MuRF received the signal, but, I don't know how to let the SPACE send this out.
    None of the 'Factor stompboxes currently transmit or receive System Real Time commands [Start; Stop; Continue].  Space's MIDI Implementation Chart  [page 48 in the manual] spells out the details.
    That would be a nice addition for control over some of the more rhythmic effects (For example: the sequencing and Restart functions in the PitchFactor's Harpeggiator.)  It might also help to clean up some of the clock sync problems reported while changing a few BPM.
    As for an immediate solution, you may have to add on a capable device (almost any drum machine, an inline MIDI footswitch device, compact MIDI sequencer, etc.).
