Home › Forums › Products › Stompboxes › Midi Expression Pedal › Reply To: Midi Expression Pedal
January 18, 2012 at 1:36 pm
#123060
Quote:
I can link midi cc to control one parameter via the utility menu.
You're almost there. Go to the same system area – MIDI: RCV CTL. Look for the PDL entry as the destination.
Quote:
What cc or program change is the stompboxes looking for in order use the midi expression pedal?
Any CC#; no Program Change numbers supported here. If you're sure that the FCB-1010 is already transmitting and the expression pedal(s) are enabled, you can skip the convoluted Behringer programming process.
If you already know the CC#, enter it next to the PDL > cc# entry. Or tap the right footswitch again in this system section to get to the LEARN area, and move your MIDI expression pedal.
