Home Forums Products Stompboxes Modfactor: Problem with unit crashing and shutting down Reply To: Modfactor: Problem with unit crashing and shutting down
#123079
    Make sure you have the very latest software (3.0.0[19] ). See the UM to find out how to check your version. There was an earlier version that misbehaved if you moved the encoder too far. Also, be sure to re-initialize the machine after this update.
    If neither of the above is the issue, you should contact support@eventide.com – we can't help you further here.
