Home Forums Products Stompboxes Eventide SPACE – Can I go from preset #1 to #50, #60… fast? Reply To: Eventide SPACE – Can I go from preset #1 to #50, #60… fast?
#123083
    The fastest method is MIDI Program Changes (usually sent from an external MIDI pedal or foot controller).  As an alternative, you can move the order of the presets around to match the sequence in your stage set.  Then Bank Up using the onboard footswitch, or Bank Down using an auxiliary switch.
