Home › Forums › Products › Stompboxes › Space Program change update request › Reply To: Space Program change update request
March 1, 2012 at 7:44 pm
#123176
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
MicrosoftInternetExplorer4
You make a very good point but consider this; parameter changes set on
the hotswitch don’t cause a noticeable glitch when toggled…so, the logic would
go something like this.
IF current preset = prog. change preset THEN reset saved parameters
ELSE load new preset
And if they wanted to be really slick, they would allow you to
configure the program change behavior and maybe even include a setting that would
allow you to choose whether the parameters should be reset or not if you’re
already on the mapped preset the program change is requesting.
