Home › Forums › Products › Stompboxes › Increased noise/hum when running Timefactor in stereo. › Reply To: Increased noise/hum when running Timefactor in stereo.
March 14, 2012 at 3:07 pm
#123225
Yes, i'm pretty sure I tried it both ways last night, and whether or not the output 2 cable was plugged into an amp or not, the noise appeared/disappeared when i plugged that cable into the Timefactor.
I will test again to make sure. If it does turn out to be a groundloop problem, is there a simple solution? I use the Voodoo Lab Pedal Power 2 and use it's AC plug to power the TimeFactor. Then i Have my amps plugged into a different power strip. Could that be causing a problem?
