Home Forums Products Stompboxes Midi Tap Tempo (Musicomlab EFX MkIII + Boss FS-5U) Reply To: Midi Tap Tempo (Musicomlab EFX MkIII + Boss FS-5U)
#123312
Gerangiro
    Connect the FS-5U to the Xpdl-input. (I have my polarityswitch to the right, but I don´t know if it matters.)
    EFX MkIII:
    Enter Editmode (hold Mode-switch until it reads PC.1)
    Press PS-1-switch until it reads ESW (it almost looks like ESu with a line over the u).
    Press PS-3-switch and change the controllernumber to (in my example) 12.
    Press Mode-switch again to step out of editmode.
    Eventide:
    Enter System-mode
    MIDI
    RCV CTL
    Change the left field from BYP to TAP
    Push the right footswitch (choosing the right field) and turn the decoder to example C12. I personally choose this because often the CC-numbers up to 11 are standard for certain parameters.
    Just check that the two units speak with eachother on the same channel…
    Gerangiro
