Home › Forums › Products › Rackmount › DSP7500 OS3.002 Update disaster › Reply To: DSP7500 OS3.002 Update disaster
April 22, 2012 at 3:57 pm
#123345
Clearly, the update has gone wrong, leaving the main memory un-programmed. You should try again several times, on a different computer if necessary. Be sure that ALL applications, especially web or network ones, are closed before the download.
If it fails at the same point every time, it could be a hardware (memory) problem. If this seems to be the case, contact support@eventide.com
