Home Forums Products Stompboxes 3-button aux switch programming question for ModFactor Reply To: 3-button aux switch programming question for ModFactor
#123363
BarneyBrown
    Troychapman: I'm also trying to work-out whether a single stomp on an Aux switch can be used to change a preset AND activate it. Your idea sounds great, but doesn't the first foot switch on the Space in play mode toggle between Active and Bypass? In which case it seems that every other preset will be BYPASSED.
    For example:
    Stomp 1 = preset 1 Active
    Stomp 2 = Preset 2 Bypass
    Stomp 3 = Preset 3 Active
    Stomp 4 = Preset 4 Bypass
    In which case think we need to ask Eventide to add an ACTIVE option to the Aux Switch part of System mode. Then we simply assign PRE+ AND ACTIVE to a single aux switch, right???
