Home › Forums › Products › Stompboxes › Timefactor – Bypass mode kills output signal › Reply To: Timefactor – Bypass mode kills output signal
April 25, 2012 at 6:18 pm
#123364
So when the effect is bypassed… you get nothing at all? When the effect is enable you get sound?
Have you enabled "KillDry" as this option is for use when in a paralel Effects Loop, the Factor only passes processed sound…you use the mix control of the Effect Loop to mix the two sounds together.
BUT if you are using the factor in front of an amp…you would not want this.
