Home Forums Products Stompboxes Pitchfactor midi out to modular synth? Reply To: Pitchfactor midi out to modular synth?
#123389
    Well, MIDI Channel selection wouldn't be an issue for MIDI Clock.   I hate to say this, but I see no MIDI Clock support listed for the A190-2 (either at this link, or found in the more in-depth manual).  Now, the A190(1) certainly seems to translate MIDI Clock into a 5V gate signal (link, and manual).  I hope that I'm missing something here, Alwaysnew.
    You could test your connections by setting the PF to MIDI: CTRL XMT=ON.  Moving a knob after putting the A-190-2 into Learn mode should give you a variable voltage out of the CV4 jack.  Again, this will simply test if your PitchFactor is transmitting something, and your Doepfler module is receiving it.
    Quote:
    Note that PF has no reason to send MIDI start or stop signals.
    … but it sure would be cool if the RESTART flex/function/footswitch in the HarPeggiator mode could XMT/RCV a Start message, Nick.  Wink
