Home › Forums › Products › Stompboxes › Fx-Loop problem…can i solved it? › Reply To: Fx-Loop problem…can i solved it?
May 8, 2012 at 9:55 am
#123416
Thank you Alan,
for your customer support!
I want to ask you,which is the "perfect" input level meter?
Before,after or above the line in the middle?
And one last thing,
…any other technique-solution except this one with the Buffer/Boost that i tried that can help improve the signal? (from fx-loop send to Eventide stompboxes)
Thanks,
Nikos
