Home Forums Products Stompboxes encoder Reply To: encoder
#123423
    Try "Restoring Factory Settings," as described in the UM. If this fails, try "Restoring Factory Effects Presets and System Settings," but note that this will erase any of your presets – you should back up anything important first.
    If this fails, it's probably a hardware issue – support@eventide.com.
