Reply To: 4000 Series unpleasant “coloration”
Home Forums Products Rackmount 4000 Series unpleasant “coloration” Reply To: 4000 Series unpleasant “coloration”
#123434
Most likely cause is incorrect levels, then ground loops. You can get a phasing effect if you mix the output with the input when using a non-delay effect type.
