Reply To: How do curves work in Distortion Module?
Home Forums Products Vsig and Preset Development How do curves work in Distortion Module? Reply To: How do curves work in Distortion Module?
#123441
DGillespie
Hi Tomo,
It looks like the documentation may be a bit incorrect.  Each curve parameter allows you to select a characteristic curve from a set of 10 possible choices (it says 19, but that is wrong).  The curve you select is the sound of the distortion, so select the one that sounds best on your source.  If you select a second curve, you can fade between the two of them via the mod input if you turn on the morphon control.  You can drive this mod input with the output of a peak module to simulate the loading effects of guitar amps, or by an lfo or something else for more innovative effects.
I hope that clarifies the module.
Thanks,
Dan
