Home Forums Products Stompboxes Timefactor Expression Pedal values keep jumping around Reply To: Timefactor Expression Pedal values keep jumping around
#123478
The music store called me yesterday after having returned the TimeFactor 3 days ago. The guy said he figured out the problem and that it was because I was using a TRS cable and should be using a mono cable to connect the expression pedal. Can you confirm this? I'm afraid I'll just waste two trips to get it and then have to return it again if it still doesn't work. Thanks.
