Home › Forums › Products › Stompboxes › POD X3pro + TF + GCP/GCX › Reply To: POD X3pro + TF + GCP/GCX
May 29, 2012 at 6:24 pm
#123484
Hi Rex,
It sounds like the MIDI command which you have set up to Bypass/Activate the TimeFactor is also changing the amp setting on the POD. So maybe you need to use a different MIDI command to do that, or change the setting on the POD if possible. For help on this I would contact Line6.
Alan
