Home Forums Products Stompboxes MIDI OUTPUT CLOCK Reply To: MIDI OUTPUT CLOCK
#123545
With the MIDI CLOCK OUT set to ON, OUTPUT set to XMT and
Global tempo OFF – Does the Modfactor send the same MIDI CLOCK OUT tempo
regardless until the tap tempo is adjusted. This is what mine is doing. Is there
a way to turn it off and on while playing as mine is always transmitting a tempo
regardless (with MIDI CLOCK OUT set to on). I realise that i
f you want Global Tempo but still have presets which ignore
the global tempo value, save those presets with Tempo OFF. Can this also be done
with the MIDI Clock out as I want other units to ignore this from time to
time.
regards
Jason
