Home › Forums › Products › Stompboxes › Time Factor ‘Line’ Noise › Reply To: Time Factor ‘Line’ Noise
#123546
    Is it possible that you are using it in a parallel effects loop, or any other way in which the input is externally mixed with its output ?
    If you are, you may need to rethink the setup. At a minimum, use the KILLDRY feature.
    If not, and you get this noise when connected guitar –  TF – amp, there is a fault and you should contact support@eventide.com
